If anyone knows, I’d really appreciate it.
Thank you.
Izabela
Hi Izabela,
I am sorry for the delay.
In general:
- You scale the dimensions up by the inverse of the amount you scale them at plot time.
There is a dimension scale setting in Settings -> Dimension Style. This will be the same for text in the next public version. - You scale the model down in Print to fit on the sheet of paper.
You mentioned you wanted to scale the model at print time by 1/4 or .25. Then you would scale the dimension (and test soon) up for 4. If you use imperial units, you would scale the model by 1/4"=1’ or 1/48 at print time. Then you would scale the dimensions (and text soon) up by 48.
I hope you see the pattern here. It is really easier that it sounds and if you use another CAD package, it may already be familiar.
I am planing to get you all details about this when I get a new build of MacRhino that fixes the Settings dialog problem on Mavericks (10.9.5.) detailed here 5A745 - Settings
But I am waiting on this fix now.
Sincerely,
Mary Fugier
