When I import/ insert another rhino file, it will import directly without showing the “render content conflict” pop-up for materials and generated new materials: Material [Imported]
Where can I reset and enable the pop-up?
Thanks
Thanks
Hello - run the command RenderImportConflictOption and choose ‘UseDialogtoAsk’
It says unknown command. Is this command for a newer version of rhino? My rhino is in version 6 SR17.
That is a Rhino 7 feature.
You may want to update since you’re trailing 17 service releases behind, latest one is 6 SR 34.
