How do I print my drawing?
Hello
I want to print my 2D drawing in Top view, 1:1, that is centered at the X0 Y0 position, but I can’t find it.
When I click the “Centered” button, I see a portion of the drawing, but it’s not the part I want to print.
I don’t understand what “Offset from Lower left, Upper left, Lower right, Upper right” means.
I’ve been adjusting the X and Y values ​​for an hour, yet I still can’t find my drawing.
In older versions of Rhino, when you selected A4 printing, an A4-sized rectangle would appear and you could move this rectangle around to choose which area to print.
In Rhino 8, there are only X and Y numerical values.
There really should be a video tutorial on how to do this, as it is quite difficult.
How can I find the specific part of the drawing that I want to print?
Thanks.
Adam
Hi Adam -
Under “View and Output Scale” in the print dialog, click the Set… button next to the “Window” option.
Thank you very much :slight_smile:. It worked.
