I want to get the Repeat factor for a bitmap texture. This shows up in the Mapping section of the UX.
Assuming the usage of RhinoCommon you can use RenderTexture.GetRepeat()
Paraphrased something like:
RhinoObject yourObject = GetSomehow();
RenderMaterial rm = yourObject.RenderMaterial;
var diffchan = rm.TextureChildSlotName(RenderMaterial.StandardChildSlots.Diffuse);
var difftex = rm.FindChild(diffchan) as RenderTexture;
Vector3d repeat = difftex.GetRepeat();
And if I am using C++ and I have a CRhinoMaterial object … how would I get to the Repeat value?
@johnc - can you help with this?
Here is some C++ code that should achieve what you need. It assumes you have a valid Rhino Document pointer handy and that the bitmap texture is in the first texture slot (‘Color’):
// Find the Render Material associated with the Rhino Material.
const auto* pMaterial = pDoc->Contents().Find(rhinoMat.RdkMaterialInstanceId());
if (nullptr != pMaterial)
// Find the bitmap texture.
// This assumes the texture is in the bitmap ('Color') slot.
const auto* pChild = pMaterial->FindChild(CS_MAT_BITMAP_TEXTURE);
const auto* pTexture = dynamic_cast<const CRhRdkTexture*>(pChild);
if (nullptr != pTexture)
// Get the repeat value from the texture.
const auto repeat = pTexture->Repeat();
Regards,
John
Very nice … yes, I have a valid Rhino Document pointer handy.
This makes sense and yes, I only want to do this when there is a bitmap assigned.
Many thanks!
