Unless your object is a block, rhino objects do not maintain a readable position value (or some kind of origin). But you could get the bounding box center or an area centroid.
those functions are not listed in the python helpfile yet, but you can read about their required arguments and description if you just start typing them in the Rhino Python editor like rs.coerce… (Under Windows).
Alternatively you might take a look what each of the functions does in the utility.py file which should be located here:
Why do you need the object? Most rhinoscriptsyntax methods work directly with the object’s GUID. For most of those methods, the GUID IS the object for all intents and purposes.
As Rhino objects do not have a built-in reference point, the “current position” is some chosen point on the object, its bounding box center or some other critera that you have to define and extract.
Hi, then how cani get object’s GUID say from a 3d point?
don’t want to use rs.GetObject(“Select object”) as you have to literally pick up a point…
Thanks!
Only Rhino objects that you have added to the document have UUIDs. The points you pick on the screen using GetPoint do not have UUIDS, as they are just points.
