I don’t see the gh file?
TELEYTAIO(MALLON).gh (12.6 KB)
thanks for answering!
edit:
needed to fix the trees
TELEYTAIO(MALLON).gh (29.4 KB)
Thank you so much!! Just one note ,the squares on the sides are missing is it easily fixable?
Not sure what you mean, the script I sent creates 152 closed breps.
these right here,thank you for your help!
Στις Κυρ 26 Νοε 2023 στις 10:29 μ.μ., ο/η Gijs de Zwart via McNeel Forum <notifications@mcneel.discoursemail.com> έγραψε:
oh rhino 6 . Maybe that’s the problem
Στις Δευ 27 Νοε 2023 στις 1:37 πμ ο χρήστης Gijs de Zwart via McNeel Forum <notifications@mcneel.discoursemail.com> έγραψε:
change this index:
TELEYTAIO(MALLON-v6).gh (27.4 KB)
thank you so much, we tried it and it worked!!
just one last question.We are trying many days now to remove this line and make it a joined surface.Is that possible?
Στις Δευ 27 Νοε 2023 στις 1:57 π.μ., ο/η Gijs de Zwart via McNeel Forum <notifications@mcneel.discoursemail.com> έγραψε:
PANEL.MONO.gh (19.3 KB)
Not behind a computer right now, but if they are coplanar you can merge them
Surface → Util → Merge Faces
i dont think they are , and it didnt work . Thanks a lot for answering though and all your help!!!
Στις Σάβ 9 Δεκ 2023 στις 11:01 μ.μ., ο/η Gijs de Zwart via McNeel Forum <notifications@mcneel.discoursemail.com> έγραψε:
Then you cannot make them 1 surface, it has to be a polysurface.
