How do I create a script to pipe everything with square sections?
Hello! Basically I’m trying to create a square sweep through the given lines.
Would appreciate it deeply if anyone could provide an advice to this situation as I’ve been struggling T_T
Thank you!!!
sweep.gh (6.2 KB)
Use Heteroptera Hetrosweep
sweep.gh (19.4 KB) I wouldn’t trust sweep for this
check this “overly complicated” option - not a sweep but you get what you want:
(edit) you can also just bring your lines into there, I was just separating your curves without the list item:
note: this works for what you have here, this doesn’t ‘pipe everything with square sections’ - for that wouldn’t you just extrude a rectangle along each line as you were doing already? :grin:
thank you for the suggestion!
Thank you for spending time on this script. I have learnt alot from it!! Thank you!
