In R V5, if I have mesh wire visibility turned on for shaded objects, how can I change the color of those wires. The default is the object color and I would like black or something else.
Thanks
Thanks
Under Rhino Options > Views > Display Modes > [your display mode] > Objects > Meshes
you can change the settings for wireframe color. Change it from Use object’s color
to Use single color for all meshes
. Then you can pick the color you like (default is black).
Thank you! wim
