How do i bend equal solid?
Hi guys, I’m trying to bend it evenly, but I would like to achieve a similar result when we use Rhinogold’s “dynamic bend” when holding SHIFT. How do I get this same result in Rhinoceros?
Hi Igor - see if the attached file does any good - the objects are edited using CageEdit where the control cage is a degree 2 by 2 surface with 3 points in each directions - only the center control point is moved.
CageEdit.3dm (110.3 KB)
Hello Pascal,
Thank you for posting this CageEdit.3dm file. I have been able to learn quite allot about the nature of NURBS geometry from it.
Andy
