@dale would you mind explaining what is ‘the proper way’ of using conduits? I have doubt because i’m creating something similar to layers and i wonder if each object (layer) should have own conduit override or should i create one instance of conduit override for handling all objects (layers) in array/list?
Please review http://developer.rhino3d.com/guides/rhinocommon/display-conduits/ . Does this answer your question?
@nathanletwory i’ve read this many times. Since there can be many other conduits i rather wonder if each ‘layer’ should have own conduit or one conduit should hold list of those ‘layers’ (objects of those layers) to display?
@D-W I suppose it depends mostly on how you want to handle this yourself. I’d go for one conduit handling them all myself, but maybe @dale has some other suggestions for this.
Yes.
– Dale
