How cant I get brep from a InsertBlock?
Hi:
I have insert a block on surface, and how cat I get brep of it? :blush:
Not sure if this is what you want:
import scriptcontext as sc
import Rhino
bloc=rs.GetObject("Select block",4096,preselect=True)
obj=sc.doc.Objects.Find(bloc)
#get definition, transform
idef=obj.InstanceDefinition
xform=obj.Geometry.Xform
#get objects that compose original definition, transform them same as block
geo=idef.GetObjects()
for g in geo: g.Geometry.Transform(xform)
#geo should now contain the objects in the block instance
#should work with any type of object, not just breps
โ€“Mitch
Think you Helvetosaur, sorry for my English, my English is not good.
I means I wan to get brep from block which have inserted, and then draw brep shaded :grinning:
I not how to draw it, but I do not kown how to get the brep.
Well, I think my example does that - the variable โ€œgeoโ€ should be a list of objects that were in the block - if they are Breps and you know how to draw them, you should be able to.
If you add these two lines to the bottom of the script, if the block was composed of Breps, it should add them to the document.
for brep in geo: sc.doc.Objects.AddBrep(brep)
sc.doc.Views.Redraw()
Think you Helvetosaur, it work and work good.
Think you. :grinning:
