How cant I add button of RHP to rhino
Hi:
I have a RHP, now I just cant run it by input command to command line, how cant I add a button to it?
If you want to create toolbars for Rhino, just use Rhino’s Toolbar command. You can save your custom toolbars in your own RUI file. For details on creating toolbars, check the Rhino help file.
And, if you give the RUI file the exact same name as the plug-in RHP file and install it in the folder containing the RHP file (or its parent folder) Rhino will automatically stage it in a writable location and open it at startup.
Thinks dale,I have got it :smiley:
