basically I want to do something like this in grasshopper
so I can later on use a bool function to make like a forniture
I could import both cubes into grasshopper, but that does not play well,because I want that the distance between each cube to be parametrical, so I can play with the (wood) table thickness
I tried to make a cube, then copy and pasting it, then using a translate node, now the problem is that I don’t ectly know how to select and translate those faces
more inside
