I already posted a grasshopper version
perhaps a viable option is to adjust seams of the curves? Seems less difficult than rotating them?
takes ~10 secs.
threw in a couple of ‘options’
rotate-curves-to-orient.gh (137.2 KB)
(edit) still probably not the best result though
Best
thing is: the curves are rotated and need to be rotated back around the point in the file with an unknown angle
Thank you, corellaman, for your suggestion!
Here I need some “jumping” curves to be rotated back to have a uniform loft surface.
yeah my apologies, totally misread and approached it wrong!
…just saw that the file I used was @Gijs 's already corrected file and that you were trying to rotate back.
I’ll go back to work instead of trying to help
Until now I can apply your rhino code :). The Galapagos component is amazing. However, the loop is still a problem.
