How can know which input has changed value?
i have 2 inputs,hoping to change one of them,then output show,which one has changed
i code as follow but failed,could someone explain it,Thank you!
      string s = "";
    protected override void SolveInstance(IGH_DataAccess DA)
        int AInput = Params.IndexOfInputParam("A");
        int BInput = Params.IndexOfInputParam("B");
        Params.Input[AInput].ObjectChanged += showAMessage;
        Params.Input[BInput].ObjectChanged += showBMessage;
        DA.SetData("print", s);
    public void showAMessage(object source, EventArgs e)
        s = "A changes";
    public void showBMessage(object source, EventArgs e)
        s = "B changes";
Try something like this:
        string s = "";
        int AInputValue = 0;
        DA.GetData(0, ref AInputValue);
        int BInputValue = 0;
        DA.GetData(1, ref BInputValue);
        if (AInputValue != m_Ainput_remember)
             s = "A was modified";
        if (BInputValue != m_Binput_remember)
             s = "B was modified";
        // Now, store ("remember") last value until checking next time
        m_Ainput_remember = AInput;
        m_Binput_remember = BInput;
// < additional code>
private int m_Ainput_remember;
private int m_Ninput_remember;
// Rolf
RIL,i tried your method,it is almost ok,but remains one problem:
if i drag the slide ,the output can show the result string,but when mouseUp,the output become “empty”…
this is code:
        string s = "";
        double A =0, B=0;
        DA.GetData("A", ref A);
        DA.GetData("B", ref B);
        if (A != m_Ainput_remember)
        if (B != m_Binput_remember)
        m_Ainput_remember = A;
        m_Binput_remember = B;
this is the MatrixToolbox.gha (26.5 KB)
there is some component in MatrixToolbox,and the component of this question is in this place:
Thank you!
