i want to remove a extruded along curve object from a bigger cube using solid difference how can i do this?
this is the object
i tried using this but in the final object one side the opening is created but the other side its not open. what should i do, if possible can u send me a sample
You can post your file to get better results/ solution.
Cheers,
BVR
i am not able to successfully solid diff from this file
Hello - if the idea is to make a hole through the box then extend the tube all the way through the box and use Boolean2Objects, cylcing through the possible results until you see the one you like, and Enter.
but i want the hole to have curves, not a straight hole
With bend pipe.
with straight pipe
cir 5 BVR re.gh (12.4 KB)
Next time try to provide proper file. No one gonna create for you.
Cheers,
BVR
thanks a lot for the help
in the bend pipe , i am not able to cap the final solid. what should i do
what did u do here, i didnt understand
