I’ve tried adjusting the camera settings, lens, angle, and switching between different views such as Perspective, Two-Point Perspective, etc., but I still can’t get it to work. The corners don’t look as “projected” or “pushed out” as they do in the reference image.
In the left viewport, it seems to me that the objects are not deformed, while at the same time, in the right viewport, they have exactly the kind of perspective I’m trying to achieve.
Your reference image is a composite with different perspectives applied to different elements. You have to produce separate images, each from its desired viewpoint, and compose them in a separate tool like photoshop to match that effect.
Could also be in the original illustration that the author is trying to replicate a ‘‘Sinar’’ camera. These are used to take photos of architecture and can be adjusted to keep the verticals more or less parallel.
OK, from that video it is less of a composite than I anticipated, but still a composite. However, getting back to your original question, the square platform you’ve circled top centre is a pretty good starting point to establish the perspective by construction. Note however that while you can do this, placing the other elements in the view will take a lot of effort because you don’t have any info on their relative size and poitions. Anyway, here’s how to set up a viewport with approximately correct camera and target positions.
Place the jpeg on a picture frame in the front viewport. I used the 1 to 1 setting, but this isn’t important.
Zoom in on the platform and draw lines to trace its edges:
Extend the lines downward until they intersect at the two vanishing points. Draw a horizon line across the vanishing points. Note that your lines will be approximations because of the quality and scale of the image, so use your judgement to tweak directions to get everything to line up. The horizon line should be horizontal (clue’s in the name).
Also drop a vertical line from the frontmost corner of the platform to the horizon line. Mark the intersections on the horizon with points. Mark the corners of the platform with points too.
In the Top view, draw a perpendicular line from the point where the vertical intersected the horizon.
Next you need to set a polyline with a 90 degree corner so that the edges pass through the vanishing points and the corner is on the perpendicular. The corner marks the station point from which the scene is viewed.
Place a square so its sides are parallel to the lines from the station point to the vanishing points, its corner is on the intersection between the horizon and the perpendicular and its size is scaled so the outer corners lie on the two recently drawn lines.
Set the perspective view to 2 point perspective (or create and save a named view as such). Zoom the view to include what has been drawn so far, then in viewport properties set the Target location to the intersection of the horizon line and the perpendicular, and set the camera location to the station point. The view should now be looking directly at the image with the target in the centre. Lock the viewport so you can’t disturb it!
Confirm that the extruded platform aligns with the platform in the image and note the camera details in the properties - the lens length should be around 8mm which is really fisheye territory.
It seems to me that this is a Two Point Perspective projection, possibly with a narrow lens (24mm or less), as the vertical lines are all perfectly parallel. Try these settings:
