So I have switched from v4 to v5 and my points all display as white , I think they have a barely visible color out line of the layer color on them but basically all points look white. How do I get the points to display as one solid color of the layer they are on . Thanks
Assuming you’re asking about Rhino for Windows…
Options > View > Display Modes > [the mode you’re using] > Objects > Points.
Change the Point style from Square with white center to Solid square.
V4 worked the same way but the Options location was slightly different.
You must have forgotten you changed it in V4.
Thank you John,I forgot about that setting.
