How can I run Rhino 6 if I don’t login internet?
Why, Rhino 6 need to login internet to run? How can I set it to run no need the login
You will need to first remove your license from your Rhino account. Then you can install it locally on ONE machine.
If you need to run it on another machine you will have to remove the license from the first machine and install it on the second - every time you change machines.
Does this mean that when reinstalling a pic with rhino 6 locally installed you’ll need to pay extra attention towards deinstalling the license first?
Yep… Otherwise it will tell you it is in use by another machine (as far as I know).
Oh, I see…, thank you!
