How can I rotate a plane?
I mean I can set it up by hand but it’s out of scope. random rotate nodes do not seem to work as I do expect
Not clear what you’re trying to accomplish.
:question:
Please explain.
:question:
Don’t see any “rotate nodes” in your screenshot.
If you want to rotate a plane, why doesn’t the Rotate Plane component work for you :question:
Post your GH code.
-Kevin
It is not clear what you are trying to do. Also please share your definition so it is easier to help you.
Having said that:
If you want to rotate a plane you could try with component Rotate Plane
If you want to rotate geometry. You can do it like so:
Also there is component Polar Array. Notice that you need to move your box a little bit away from the P input of Polar Array. If not polar array will be done with all boxes at the same place.
Moved.
Not Moved:
