i have to remove a sphere shaped volume from inside a cube. How can i do this? any help would be great.
thanks in advance
thanks in advance
Is this what you try to realise?
I’m trying to remove a lot of small sphere shape volumes from inside cube, I’m not able to remove from inside the cube
Make sure you have a hole inside your outer Geometry. Otherwise the boolean will fail.
I guess like this, a small tube connecting both volumes?
Yes.
What if I have to remove multiple small spheres then?
If the spheres are not in contact you should do it for all.
Is split/difference available in default?
Is it ok if you could share the circuit?
I have no idea what that is.
I’m new to grasshopper, so if you could share the circuit it would be great
Mahan did you understood what I’m trying to build?
i meant the opposite to happen , spheres should disappear leaving cavities in cube
Yes. That’s exactly what I did. you have to bake the result(The last Brep).
SphereBox boolean1.3dm (2.1 MB) SphereBox boolean1.gh (13.4 KB)
