How can I manually adjust a fillet between 2 edges?
As you can see I need to fillet the right edge so I can sweep or blend those edges together. But since it has a constant radius, it doesnt fillet between those 2 edges. How can I create a fillet and snap where I want it to start/finish?
FilletEdge2.3dm (273.1 KB)
Hi M.E,
this tutorial might help you: “Modeling Complex Transitions” https://vimeo.com/109184032.
ED77
thank you. i have already looked at it, it s just, i have used that tutorial but he doesnt explain the last fillet i have. we dont have similar models
im thinking about triming that edge away and maybe sweep/blend those surfaces to get an even surface
First of all you won’t get very far using filletedge command. It’s capabilities are very limited.
Filletsrf on the other hand is very robust command but since McNeel has refused to add any automation to this process you will have to do each and every step manually. But it is still much faster and more reliable then making fillets with blends and/or sweeps.
The easiest way to deal with those corners is to make the one fillet
crossover the other. See enclosed file.
Fillet_crossover.3dm (307.5 KB)
All four corners can be done as crossover fillets (shown in red). Two of the corners you can crossover the natural extension of the fillets and the other 2 corners you need to steer the fillet extension inward so that the other fillet can crossover it. There is another recent thread that has an explanation of how that is done.:
