I just want to make this rule of grasshopper.
Rotation of central rectangular can make others move.
- Create the alpha square.
- Extract corner points
- From corner points you create A, B, C and D.
- Once again extract corner points from A, B, C and D
- Use these points to create the outer squares.
- Add rotation to alpha square (at start)
If you are looking for a way to do it with more than these squares, you might wanna look into another solution.
thanks a lot!
Can you tell me how make more squares around these squares if you know?
Thats the issue, the solution i gave you, will only work as long as you have patience to work with it and is not particularly parametric, since you would have to repeat step 2-3 agian and again for more squares.
I think the “proper” way to do it, would be
A rectangular grid
Find the center rect
Cull those that are inbetween A, B, C and D
Rotate center box globally and every other locally (at their respective centerpoint)
Then recreate the skewed rect (those we culled) from lines created by endpoints.
