How can I make boundary surfaces from these two lists of curves?
Ellipsoid.gh (25.5 KB)
You could use this RhinoCommon method:
I forget if it has been implemented in Grasshopper yet, but the script works natively.
Thank you!
  1. Solution exception:‘NoneType’ object has no attribute ‘Ngons’
    It’s working now, but I still have to modiffy the definishion.
    Ellipsoid.gh (31.0 KB)
You can do something like this too:
Ellipsoid_b.gh (46.9 KB)
Note:
You might have to simplify your top/bottom panels to avoid the curve/pinch - not sure what the design specs are there.
'Hope it helps!
RC
Tanks René! But I have a missing component:
I want to try to understand how it’s working.
I think that I need a horizontal lines to make a surfaces, I got to these 3 polylines, but I don’t know how to create separate triangles from them.
Ellipsoid.gh (36.2 KB)
Oh, sorry - that’s a RemoveDuplicateLines - strange, it should be there.
Here’s a workaround:
Ellipsoid_c.gh (47.4 KB)
Looking at this image it seems you could simply pull the boundary curves onto your surface and then split the surface using those curves - slower brute-force process but might work
Thank You! I’ts very helpful if with that center points I can mesure the angles bethwin nonecoplanar triangels.
Great! Also, regarding that pinch on the bottom panels, I guess a ‘four point surface’ component can be used (omitting one point for the bottom row of panel boundaries.
Cheers!
I found I can use Lunch Box diamond panels.
Finaly it’s working!!!
Lunchbox Grasshopper Tutorial (Diamond Panels).gh (17.1 KB)
NICE WORK…can you please point me to the tutorial…I can only find one for the framework
I used this for the framework, other I’ve made on my own.
as a follow up to this …is there a method in GH to find all the surfaces resulting from intersecting lines ? I know I can achieve this individually with network curves and wondered if there is a way to detect all the possible surfaces.
The two curve components are seperated into horizontals and verticals.
network surface.gh (7.0 KB)
try region
I can find intersecting regions individually but it doesn’t find multiple regions…
surface.gh (16.4 KB)
thank you…I thought there must be a way with surface split but I got stuck…I also found the solution by David Stasiuk…Closed Curve Intersection Network - Grasshopper
there’s also a very nice class for that in rhinocommon: https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.curvebooleanregions?version=8.x
a very poorly-implemented Python as a single component solution:
CurveRegions.gh (17.9 KB)
