I’m trying to make a symmetrical ark by knowing the diameter and the depth but i cannot find such an option.
I could make it from Ark-> Start, End, Point but then i would have to calculate the co-ordinances of the Point.
Am i missing something ?
I would say that the easiest way with standard Rhino tools would be to make a line from the start/end points of the arc, then use Offset by the depth you want. Then use Arc > Start, End, Point on Arc, and snap to the midpoint of the offset line.
Won’t Arc - Start, End, Radius do what you want? Or am I not getting what you’re after?
Nope.
For ex. for an ark of 100 diameter and 10 depth the Radius is ~130.
That is so easily done in Sketchup i am surprised Rhino doesn’t have it.
Exactly
If you have a symmetrical arc and the start, end and diameter are known then there is only one possible position* for the centre, so depth is irrelevant. Just use Arc, Start End Radius.
Regards
Jeremy
- Two if you count the mirror image.
By diameter i mean the distance between start and end not the lenght of the arc
That’s the chord length.
Draw a rectangle length = chord, height = depth, draw an arc from start, to end, passing through mid-point of parallel edge.
Here is a quickie hack script - it doesn’t have any dynamic preview of the arc though…
ArcStartEndDepth.py (989 Bytes)
@nikoskostantopoulow And here is one with a dynamic preview, depth can be entered via the keyboard or chosen with a mouse pick on screen.
Edit - small update: now remembers last used value and nicer preview for first two points.
ArcStartEndDepth.py (2.1 KB)
Thank you.
Can you make one that diameter can be endered by keyboard also ?
Doesn’t make a lot of sense for this script - Rhino already has a command for Arc>Start, End, Radius.
As Rhino 6 accepts command-line math, you can also enter diameter/2 for the radius value.
Would this work?
- Assume you have the 2 end points (at a known distance) that represent the chord length. They could be actual points (e.g. corners of rectangles) or snaps (e.g. quads, mids, etc).
- create a temporary line between the 2 points
- start Arc>start, end, point on arc
- pick start and end but at point on arc use the perpfrom osnap.
- pick the line, pick it’s midpoint, put the cursor on the proper side of the chord line, enter the depth value on the command line, and hit return.
- delete the temporary line.
