How can I join separate points of a surface?
I would like to know how could I do the same as the images uploaded, going from the red one to the blue one. Thanks
hi,
select the red one pres "F10"
select the top control points
type "setpt"
click to desired coordinate to place all selected points.
do the same steps for bottom
but modeling it from the scratch will give you a better form, because red surface has more points than blue one
regards
have any other way to do this? i was trying to move points but it would not deliver good results
hi,
draw an arc
mirror it
draw another arc to define the back side of the surface
use this tool and click every arcs’ mid point to make the crossection curve
use network surface and select all the curves
regards
