I’m trying to export an stl file to import into 3dCoat, but my model’s surface isn’t smooth due to low poly count. Is there a way to increase the poly count in Rhino’s stl export’s setting?
Thanks
Ok I found that I needed to increase the “Maximum distance, edge to surface” value
Problem solved
