How can I get white hatch to show as white?
V5
white shows as grey stencilling
stencil lettering given white hatch solid fill, shows as grey, and the shape has a white edge, which when zoomed out gets thicker destroying the appearance, in Shaded Mode.
I wish to show someone how the item is looking but not with thick white edges and a grey interior fill !
How does one solve this ?
Steve
Dunno, a white hatch displays as white here in V5…
it probably depends in which display mode you are showing these, you can edit the display modes not to show edges, though for hatches edges should not be shown by default (if i am not totally derailed today, which i probably am :smiley: ) so i am a bit confused, but i am sure you can set that all, usually.
I was going to say something similar. There is some different things that could cause it but I would check the viewport display settings first. It seems to work here.
