I’m using Rhino 7 and trying to Loft a surface through several closed cross-section curves stacked at different heights (see images). My end goal is a clean solid I can 3D print.
The problem: between the sections the loft twists and pinches/self-intersects
With Style: Normal and “Do not simplify” the surface comes out messy.
What I’ve tried (the twisting persists in all of these):
Loft Options → Rebuild with 10 control points → still twisted
Rebuild with 50 control points → cleaner, but still not usable
Running the Rebuild command directly on the input curves, rebuilding both curves to the same values / same control point count
Lofting with no rebuild at all
My question: How can I do this Loft properly and get a clean result?
I can attach the .3dm file if that helps. Thanks in advance!
