How can I find the location of a block reference
Dear all,
I want to remove a layer from the model, however it is blocked by a block reference. The model contains hundreds of block definitions, and I would need an easy way to find out which block contains the nested one so that I can remove it. Is there a way other than stepping through each block definition, open the block manager and see if it contains the unneeded definition?
thanks
Cyana
Hi Cyana - do you want to enter an instance name or select an instance and get a list of layers that are occupied?
See if this gets you what you are looking for -
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
InstanceDefinitionLayers.py (725 Bytes)
This one, if I did it right, will tell you all the layers ‘occupied’ by an instance, including the instance layer, at the top of the list.
BlockLayers.py (1.4 KB)
Hi Pascal,
thanks a lot for the script! It’s not exactly what I was looking for, however it perfectly helps detecting unexpected layers within block definitions.
Maybe a future block manager can display an inheritance tree of block definitions - this would be very helpful. And - as Xmas is approaching - another wish to NcNeel Santa - something like an object tree like for instance in SimLab Composer.
thanks
Cyana
