When I enter the “4” key and enter, the “4view” command will execution, and delete all the existing view, so I want to disable 4view command or resum the last all view, thank you!
If there was a saved file before “4View” and you did not save the file after “4View”. you can use the ReadViewportsFromFile command to re-read the previously saved file to restore the viewport settings.
ok, thank you very much!
