How can I create centroid from attached block?
Block centroid.gh (6.2 KB)
block.3dm (24.8 KB)
Hi @sajesh_pj ,
I can’t open your .3dm file, as it is a Rhino 7 file, but check the attached definition.
You just need the “Area” component to get the centroid.
Block centroid2.gh (2.5 KB)
updated with Rhino 6 file. Can you check this?
If you deconstruct block, it is not a closed curve to get centroid.
Since your curves are overlaying in this special case I think the simplest would be to get a boundingbox(right click to set it to union box) and take its center:
