Hello forum, I’ve been getting back with the basics after long years of absence with GH and got cought up with this problem;
I was trying to model some simple chair model all in GH and wanted to be able to change the backrest slope with a nr slider however I couldn’t find a way to create a definition that would send data between some domains.
Here is a simple drawing to clarify what I wasn’t able to explain
Necessary also that the flow carries actual slider data [if x=2 go to first node with f(x)=2…]
Here is the definition in case you are wondering but there is not much to look at there.
unnamed.gh (45.0 KB)
Thank you very much and hope I was clear enough
