I’ve tried loft but can’t get the curves to align at all (I don’t think I really know how to align them) Patchsurface gives wonky results with the center of the surface either bulging up or down. I don’t really know how to go forward with building this surface. If you have any ideas it would be greatly appreciated!
@pascal Thanks for the solution! I realize the logic of it is very easy and smart, I just didn’t see it. Your method helped me to create the surface where the number of connecting arms are larger than 3.
@Stratosfear Your solution seems to be the most visually appealing but I couldn’t really understand the logic from the images provided. What command did you use to create the surfaces? Do I really need to remove the planar flat spot? Is your surface the more correct one, in mathematical terms? (Is the red highlighted surface included in your solution, or is that the part you remove and replace?)
