su.lwpac
(Su Lwpac)
May 29, 2020, 12:02am
1
@stevebaer @brian I am working with the Gumball documentation and would like to know if the numeric textfield is available anywhere to access.
I have been trying to search through the API documents, but no luck so far.
Can you guys please point me to the right direction. Thanks.
brian
(Brian Gillespie)
May 29, 2020, 12:04am
2
Hi @su.lwpac , I think @mikko knows the most about this.
Are you working in C++ or C#?
su.lwpac
(Su Lwpac)
3
@brian I am working in C#
dale
(Dale Fugier)
May 29, 2020, 8:55pm
4
Hi @su.lwpac ,
The numeric fields, provided by the gumball, are not available in any API we provide.
Why do you need access to this? Are you using your own gumball implementation or do you want access to Rhino’s “auto” gumball?
– Dale
su.lwpac
(Su Lwpac)
May 29, 2020, 9:17pm
5
Hi @dale ,
Yes i am implementing my Gumball feature. I really like the fact that when you interact with Gumball in Rhino, it gives you the flexibility to either manipulate geometry intuitively or with numbers.
I am thinking it will be a good to have that possibility when one is trying to implement Gumball in there code-tasks.
@su.lwpac , you can implement that by using a form with textbox only. Here is a link to @Dani_Abalde 's Github where he shared the Code for his Gumball for Grasshopper: https://github.com/DanielAbalde/GhGumball
You can also read about the same on Grasshopper forum here: https://www.grasshopper3d.com/profiles/blogs/gumball-for-grasshopper
These information will get you started with what you want.
su.lwpac
(Su Lwpac)
November 24, 2020, 5:14pm
8
Thanks. It is what I wanted. although he has written all of it in VB. I will post the code once I have it working in C#.
Thanks again.
