hi , i want add tab in ribbon like this
waht should I do to implement it.
You should check out the Workspace editor. Adding a new toolbar (which you call a tab) is described there.
thank you. I have read the post and find that is just a modification to my current computer. But I hope that after installing the plugin, the user ribbon can also be modified accordingly. Could you please use code to make this modification, or add any configuration files to the installation package so that users can load the ribbon directly
You should be able to add your modifications to a separate RUI file, that can be distributed together with your plug-in. You should have two files with the same name, and extensions RHP (plug-in) and RUI (user interface) and Rhino will load the RUI automatically when the plug-in is loaded.
MyPlugIn.rhp
MyPlugIn.rui
thank you . I have modified the ribbon
thank you
