How about double-click to show all parameters as a shortcut?
Not that this is the same but you can single click the little arrow that shows up in the ZUI but that does require you zooming in that close.
Yeah that’s actually ok too
Currently it does something similar.
- Shift + Double click Expands
- Ctrl + Double click Collapse
Similar to when you connect a wire Shift adds while Ctrl removes a wire.
Ok, this is a good solution.
After Shift+LMB double click my Bake component goes green (selected) and I need to deselect it to see the Bk input.
It works as expected on other components.
Fixed for the next.
