To see the changes applied during a hot reload, the changed code needs to be run again. In this case, I guess, you need to create a new instance of the panel, or call some method that reloads the layout of the panel.
Hi, I tried looking in Rhinocommons and I couldn’t find anything under Panels class to reload the Panel, neither could I create another instance of Panels.
Can someone help me with this?
below is the code:
namespace Terrain.Commands
public class OpenTerrainPanelsCommand : Command
public static OpenTerrainPanelsCommand Instance { get; private set; }
public override string EnglishName => "Terrain";
Panels.RegisterPanel(PlugIn, typeof(Views.TerrainPanel), "Sample", Properties.Resources.TerrainIcon, PanelType.PerDoc);
var panel_id = Views.TerrainPanel.PanelId;
var visible = Panels.IsPanelVisible(panel_id);
if (!visible)
Panels.OpenPanel(panel_id);
else
Panels.ClosePanel(panel_id);
// TODO: complete command.
return Result.Success;
One way is to set the Content property of a panel inside a method that you can call, rather than in the constructor. For example:
public class SamplePanel : Panel
public SamplePanel(RhinoDoc doc)
SetContent();
void SetContent()
Content = new StackLayout()
Orientation = Orientation.Vertical,
Items =
new Label { Text = "Hello world" },
new Button((s, e) => SetContent()) { Text = "Update panel" }
If you change the text of the label in your ide and hot reload, pressing the button will update the panel and show the new text without having to restart Rhino.
It doesn’t have to be a button in the panel, it could be called by any code that you can trigger easily. In your code you seem to show/hide the panel, so you could add this:
The problem remains that, when I change the Panel, like adding a new slider in the ETO form, I would like to test it out with Hot Reload.
I cannot make a SetContent method every time I add something new. it would be quite clumpsy.
Is it true? Not sure though.
What do you mean with making a SetContent method every time you add something? You just have to edit the same SetContent method. In my example above, you just have to add one extra line:
void SetContent()
Items =
new Button((s, e) => SetContent()) { Text = "Update panel" },
new Slider()
and a slider will appear under the button, without having to re-open Rhino.
