Host boundary profile not in same plane as host
When I use Host Boundary Profile on floors, for some floors the profile seems to lie in a different plane. In Revit they look correct and in Rhino their brep is correct, it is just the profiles.
Planes are correct too so I can simply project these profiles to the correct planes, but wanted to know if there is an explanation for this behavior ?
Hi @ahmedwael.si,
Could you please share a Revit and a Grasshopper file?
It depends on the Floor Reference Level. Check the following circled note.
I should fix this.
The curves should lay on the plane even Revit stores the floor sketch on the reference work-plane.
Hi Kike,
Yes sure. I can send you the files.
This will be fixed on v1.36.
