Hello!! I stumble on something probably easy, but well, I can’t manage it: either a sheet of cardboard (so a small thickness), with a slightly horny corner … what I get is never “clean”, the “hinge” is always protruding, and again I have not tried with a thickness! thanks for your advice!!!
thank you Encephalon
!!! it works very well! but, how to give a little thicker? shifting the surface does not work well … thank you!use OffsetSrf.
best you replay to comments directly, just coincidentally saw that you replied.
