I am trying to debug a failing gh script, when ran via compute.
I encountered first some errors now solved, see here Rhino 8 Hops/Compute Issues - Grasshopper / Hops - McNeel Forum,
The issue I have now is something weird as follows. I am using a local compute instance. @AndyPayne could you hint how I could try debugging this ?
Is it possible to attach a simple Hops/Grasshopper definition that you’re sending to rhino.compute where this error occurs so we can test things on our end?
