HOPS Help! How to fix grasshopper to use native compute server
I need a bit of help…
I was using hops natively in grasshopper with no issues.
I then installed and compiled the code to run an external compute server, which works fine.
Now I can no longer use hops without first manually starting the external server and would like to revert the default operation to use the server that comes with grasshopper.
Can anyone help me?
