We’re also learning how to do a better job of support :). If you would have pasted just a little more json in your screenshot above I would have caught it.
Can you confirm that the server is indeed running and that the endpoint is spelled correctly as to what’s being defined in the server side code? You’ve probably got it correct but it’s worth double checking. In fact, could you copy you’re /pointat definition in your python server code so I can take a look?
Also there was a recent update to the ghhops_server library. You may want to run the pip install command to update it to 1.5.4.
