Hops Asynchronus stuck again.....need help to understand
I had an issue with hops async which I thought I solved it in the last post -
However, this method stops working with there are many async hops components in the canvas. I am unable to share the gh file. I have attached a video showcasing the problem -
I am unsure why the Hops component gets stuck. Is it getting stuck because of receiving a null input for a split second? If that is the case then do I need to programmatically expire the Hops component using scripted components/ metahopper?
Why is this only happening when there are multiple hops components present in the canvas? Is there something I can do with the hops preferences? Are the max concurrent requests/ timeout/ cache/ child process counts having an effect on the hops execution? This is what it looks like right now.
