I try again, Hops sever don’t start automatically, this feature still needed, i don’t know why it work before! * Can we see this as option in hops component to run the python file automatically when use hops?
it’s a diversion from the topic but you seem to be using multiple python projects with dependancies and without virtual environments : I definitely recommend taking the time to learn virtual environments if that is the case - the main advantages are
if you have an unusual dependency in one project it won’t ‘pollute’ all your projects
If you have complex dependencies like Scipy or Flask then you can upgrade them in one project without worrying that the upgrade will break other projects
If you completely break your environment for one project you can delete it and start again
