Hops and PyQt5 app
Hello
I connect this app created with PyQt5 and python with flask and ghhops.
As you can see in the video when i create new shapes i need to recompute to receive the new data.
Is there a way to make hops automatically receive the new data?
What if you wire a trigger component to the Hops component to call your python server on a regularly scheduled interval?
Thanks @stevebaer
Yes it works , but doesn’t this make Python and Grasshopper run slower?
Yes it is more work, but at least it works :slight_smile:
Thanks , i hope that Hops will have autoupdate option
I find another way , i remove flask server and save output data to txt file and load the txt file in Grasshopper with Synchronize enabled.
This update all datas in realtime.
This give me an idea to control gh file with python, i will try with sql to compare speed.
