I’m working on a daylight simulation using Honeybee, but it doesn’t seem to work properly. The simulation runs without errors, but I don’t get any results or visual output, so I’m not sure what’s going wrong.
Also, I would like to perform an annual glare analysis, but I’m not sure how to set it up correctly in Honeybee. Could someone please explain or guide me step-by-step on how to do this?
That’s correct. You need to spend a certain amount of time and read a number of posts before you are allowed to upload files on that forum. You should always read the guidelines for any forum that you are new to. In addition to that, you should also always search for previous answers to your question. Those two things alone will likely make it so that you can post your files.
… and it also probably beats not getting any answers here…
