I’ll let you know after I get back to work
Hm, that’s about all of them… did you by chance have another instance of rhino running?
Running, no.
I have RhinoWIP installed.
update: On this PC I’m with Windows 7 if it’s relevant.
rfollett
the https://discourse.mcneel.com/uploads/short-url/yclnkuaAXCw1YEEJzD0Q3yyRezq.rhi download provided does not install as it ask “how do you want to open this file?” Any thoughts? Older version “holomark2sr1.rhi” works fine.
Any help is appreciated
Had this problem to, the solution is somewhere here, would be nice to be able to pin things like that.
The solution I got was that you just have to add the file extention ‘.rhi’ on the end of the file name.
Just rename the file and add ‘.rhi’.
I understand that some people do not have file extensions automatically shown in their file explorer, so they don’t realize the file extension is missing.
That did it!
Wow
Thanks
Holomark 2 R6 v2,61
Total Score: 287726
Total Runtime: 1304.62 sec
GPU scores: 269780
GPU_01 - 175.40 fps - Cube 4 tests
GPU_02 - 88.50 fps - UDT Shape
GPU_03 - 909.10 fps - Wireframe
GPU_04 - 714.30 fps - Shaded
GPU_05 - 178.60 fps - Rendered
GPU_06 - 158.70 fps - Block Rendered
GPU_07 - 1160 units Nurbs @ 5 fps in Wireframe
GPU_08 - 571 units Nurbs @ 5 fps in Shaded
GPU_09 - 119 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 277.80 fps - RenderMesh Render
GPU_11 - 769.20 fps - RenderMesh RenderSpeed
GPU_12 - 714.30 fps - JoinedMesh Render
GPU_13 - 1250.00 fps - JoinedMesh RenderSpeed
GPU_14 - 145 units mesh @ 15 fps in Shaded
GPU_15 - 277 units mesh @ 15 fps in Render
GPU_16 - 827 units mesh @ 15 fps in RenderSpeed
GPU_17 - 277.80 fps - mesh in Rendered Studio
GPU_18 - 56.50 fps - Nurbs in Rendered Studio
GPU_19 - 67.60 fps - Block Illustration
GPU_20 - 226.80 fps - 2D single
GPU_21 - 116.10 fps - 2D massive (20x)
CPU scores: 17946
CPU_01 - 5.81 sec - Booleans and Contours
CPU_02 - 1.04 sec - Twist and Taper (UDT)
CPU_03 - 9.43 sec - Meshing Mini
CPU_04 - 0.02 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 7.99 sec - Reduce Mesh
CPU_07 - 0.74 sec - Calculating Technical display
CPU_08 - 2.81 sec - Making Silhouettes
Notebook
P7xxTM1
NVIDIA GeForce RTX 2070 - 4095.0 MB
DriverVersion: 26.21.14.4266
Intel® Core™ i9-9900K CPU @ 3.60GHz
NumberOfCores: 8 NumberOfLogicalProcessors: 16
MaxClockSpeed: 3.6 GHz
TotalPhysicalMemory: 32.0 GB
Microsoft Windows 10 Pro
- None - 64-bit
Rhino 6 sr 26 64 bit
Holomark 2 R6 v2,61
Total Score: 302310
Total Runtime: 1440.14 sec
GPU scores: 284460
GPU_01 - 99.00 fps - Cube 4 tests
GPU_02 - 85.50 fps - UDT Shape
GPU_07 - 1229 units Nurbs @ 5 fps in Wireframe
GPU_08 - 531 units Nurbs @ 5 fps in Shaded
GPU_09 - 121 units Nurbs @ 5 fps in RenderSpeed
GPU_11 - 714.30 fps - RenderMesh RenderSpeed
GPU_12 - 588.20 fps - JoinedMesh Render
GPU_13 - 769.20 fps - JoinedMesh RenderSpeed
GPU_14 - 183 units mesh @ 15 fps in Shaded
GPU_15 - 577 units mesh @ 15 fps in Render
GPU_16 - 1449 units mesh @ 15 fps in RenderSpeed
GPU_17 - 303.00 fps - mesh in Rendered Studio
GPU_18 - 55.60 fps - Nurbs in Rendered Studio
GPU_19 - 66.70 fps - Block Illustration
GPU_20 - 191.90 fps - 2D single
GPU_21 - 106.30 fps - 2D massive (20x)
CPU scores: 17850
CPU_01 - 5.67 sec - Booleans and Contours
CPU_02 - 1.02 sec - Twist and Taper (UDT)
CPU_03 - 9.00 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_06 - 8.69 sec - Reduce Mesh
CPU_07 - 0.77 sec - Calculating Technical display
Dell Inc.
Precision 7750
Intel® UHD Graphics - 1024.0 MB
DriverVersion: 26.20.100.7870
NVIDIA Quadro RTX 5000 - 4095.0 MB
DriverVersion: 26.21.14.4283
Intel® Core™ i7-10850H CPU @ 2.70GHz
NumberOfCores: 6 NumberOfLogicalProcessors: 12
MaxClockSpeed: 2.71 GHz
- None - 64-bit
AA level = 4
Holomark 2 R6 v2,61
Total Score: 344196
Total Runtime: 1570.54 sec
GPU scores: 324060
GPU_01 - 196.10 fps - Cube 4 tests
GPU_02 - 99.00 fps - UDT Shape
GPU_03 - 1250.00 fps - Wireframe
GPU_04 - 1111.10 fps - Shaded
GPU_05 - 200.00 fps - Rendered
GPU_06 - 188.70 fps - Block Rendered
GPU_07 - 1339 units Nurbs @ 5 fps in Wireframe
GPU_08 - 634 units Nurbs @ 5 fps in Shaded
GPU_09 - 131 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 370.40 fps - RenderMesh Render
GPU_11 - 909.10 fps - RenderMesh RenderSpeed
GPU_12 - 769.20 fps - JoinedMesh Render
GPU_13 - 1666.70 fps - JoinedMesh RenderSpeed
GPU_14 - 180 units mesh @ 15 fps in Shaded
GPU_15 - 333 units mesh @ 15 fps in Render
GPU_16 - 1305 units mesh @ 15 fps in RenderSpeed
GPU_17 - 370.40 fps - mesh in Rendered Studio
GPU_18 - 63.30 fps - Nurbs in Rendered Studio
GPU_19 - 78.10 fps - Block Illustration
GPU_20 - 302.10 fps - 2D single
GPU_21 - 156.00 fps - 2D massive (20x)
CPU scores: 20136
CPU_01 - 5.25 sec - Booleans and Contours
CPU_02 - 0.91 sec - Twist and Taper (UDT)
CPU_03 - 8.55 sec - Meshing Mini
CPU_06 - 6.91 sec - Reduce Mesh
CPU_07 - 0.68 sec - Calculating Technical display
CPU_08 - 2.49 sec - Making Silhouettes
Micro-Star International Co., Ltd.
MS-7B17
NVIDIA GeForce RTX 2070 SUPER - 4095.0 MB
DriverVersion: 26.21.14.4166
- None - 64-bit
Rhino 6 sr 27 64 bit
AA level = 4
Thanks for giving us this useful tool! I benchmarked my Pc (i7 6700k w/ Gtx 1080 i built it about 4 years ago) and my dad’s PC which i built on december (Ryzen 3900x w/ Quadro P4000) I built my computer for gaming and regular use and my dad’s as a workstation but i see that mine has better fps than the quadro is that normal?
Also my runtime was 971.15 seconds while my dad’s was 677.44. I noticed on high end benchmarks such as jeff’s that they have greater runtimes, i thught the built i did for my dad would be superior than mine as It has a Samsung 970 PRO NVME, Quadro p4000, Ryzen 3900x, MasterLiquid ML360R and mine has a regular ssd, no water cooling and i7 6700k with 1080 gtx. Am i missing something?
Anyways here’s the results i got.
Come on, guys, don’t keep it to yourselves, show us your secret GeForce RTX 3090 Holomark scores!
Recently built a new PC, but still holding out for those new GPUs. Will update with finalised figures when I get one!
i7-10700K
GTX 960
yeah it is better than my i5-9400F
hi! how to read this score? how bad is my pc?
Holomark 2 R6 v2,61
Total Score: 151578
Total Runtime: 697.9 sec
GPU scores: 137370
GPU_01 - 174.70 fps - Cube 4 tests
GPU_02 - 61.70 fps - UDT Shape
GPU_03 - 625.00 fps - Wireframe
GPU_04 - 416.70 fps - Shaded
GPU_05 - 116.30 fps - Rendered
GPU_06 - 106.40 fps - Block Rendered
GPU_07 - 485 units Nurbs @ 5 fps in Wireframe
GPU_08 - 258 units Nurbs @ 5 fps in Shaded
GPU_09 - 91 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 178.60 fps - RenderMesh Render
GPU_11 - 400.00 fps - RenderMesh RenderSpeed
GPU_12 - 434.80 fps - JoinedMesh Render
GPU_13 - 714.30 fps - JoinedMesh RenderSpeed
GPU_14 - 86 units mesh @ 15 fps in Shaded
GPU_15 - 183 units mesh @ 15 fps in Render
GPU_16 - 627 units mesh @ 15 fps in RenderSpeed
GPU_17 - 204.10 fps - mesh in Rendered Studio
GPU_18 - 36.00 fps - Nurbs in Rendered Studio
GPU_19 - 58.80 fps - Block Illustration
GPU_20 - 68.00 fps - 2D single
GPU_21 - 9.80 fps - 2D massive (20x)
CPU scores: 14208
CPU_01 - 6.56 sec - Booleans and Contours
CPU_02 - 1.47 sec - Twist and Taper (UDT)
CPU_03 - 8.71 sec - Meshing Mini
CPU_05 - 0.07 sec - Join Render Mesh
CPU_06 - 14.23 sec - Reduce Mesh
CPU_07 - 1.21 sec - Calculating Technical display
CPU_08 - 2.91 sec - Making Silhouettes
To Be Filled By O.E.M.
NVIDIA GeForce GTX 1060 6GB - 4095.0 MB
DriverVersion: 26.21.14.4614
Intel® Core™ i7-8700K CPU @ 3.70GHz
MaxClockSpeed: 3.7 GHz
TotalPhysicalMemory: 16.0 GB
Microsoft Windows 10 Home
- None - 64-bitowy
Rhino 6 sr 29 64 bit
AA level = 4
Holomark 2 R6 v2,61
Total Score: 295272
Total Runtime: 1300.41 sec
GPU scores: 269930
GPU_01 - 930.20 fps - Cube 4 tests
GPU_02 - 78.70 fps - UDT Shape
GPU_03 - 1111.10 fps - Wireframe
GPU_05 - 181.80 fps - Rendered
GPU_06 - 144.90 fps - Block Rendered
GPU_07 - 1005 units Nurbs @ 5 fps in Wireframe
GPU_08 - 344 units Nurbs @ 5 fps in Shaded
GPU_09 - 99 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 294.10 fps - RenderMesh Render
GPU_14 - 204 units mesh @ 15 fps in Shaded
GPU_15 - 564 units mesh @ 15 fps in Render
GPU_16 - 2105 units mesh @ 15 fps in RenderSpeed
GPU_18 - 43.30 fps - Nurbs in Rendered Studio
GPU_19 - 73.50 fps - Block Illustration
GPU_20 - 79.30 fps - 2D single
GPU_21 - 12.30 fps - 2D massive (20x)
CPU scores: 25342
CPU_01 - 5.40 sec - Booleans and Contours
CPU_02 - 0.99 sec - Twist and Taper (UDT)
CPU_03 - 2.56 sec - Meshing Mini
CPU_06 - 7.57 sec - Reduce Mesh
CPU_07 - 0.67 sec - Calculating Technical display
CPU_08 - 2.50 sec - Making Silhouettes
Gigabyte Technology Co., Ltd.
Z490I AORUS ULTRA
NVIDIA GeForce RTX 3080 - 4095.0 MB
DriverVersion: 27.21.14.5638
Intel(R) Core™ i7-10700K CPU @ 3.80GHz
MaxClockSpeed: 3.79 GHz
TotalPhysicalMemory: 64.0 GB
- None - 64-bit
AA level = 4
@alistair.munro, one question. Did you order your 3080 on day one? Because I did and I don’t have it yet. The shop says they have no idea when they’ll get more.
An RTX 3080 with 4095 Mbyte of VRam?
Something seems fishy to me…
I am the fish!
Holomark checks in the windows registry and that part that I used is probably so old that it is 32bit compatible. I don’t know where to look for the true Vram amount though, so if you find it then please shout out
Which Registry key are you looking at? And what data type are you storing it into?
There are two keys that NVidia uses:
HardwareInformation.MemorySize - 32bit value
HardwareInformation.qwMemorySize - 64bit value
…but you have to be looking in the right place.
-Jeff
