Holomark 2 Scores (Searchable Text Results)
This is a friend’s custom build:
Holomark 2 v2,2,03
Total Score: 51173
Total Runtime: 160.05 sec
GPU scores: 35430
GPU_01 - 1290.30 fps - Cube 4 tests
GPU_02 - 37.90 fps - UDT Shape
GPU_03 - 52.90 fps - Wireframe
GPU_04 - 60.20 fps - Shaded
GPU_05 - 44.10 fps - Rendered
GPU_06 - 42.70 fps - Block Rendered
GPU_07 - 22 units Nurbs @ 5 fps in Wireframe
GPU_08 - 14 units Nurbs @ 5 fps in Shaded
GPU_09 - 46 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 156.30 fps - RenderMesh Render
GPU_11 - 263.20 fps - RenderMesh RenderSpeed
GPU_12 - 256.40 fps - JoinedMesh Render
GPU_13 - 204.10 fps - JoinedMesh RenderSpeed
GPU_14 - 7 units mesh @ 15 fps in Shaded
GPU_15 - 10 units mesh @ 15 fps in Render
GPU_16 - 26 units mesh @ 15 fps in RenderSpeed
GPU_17 - 137.00 fps - mesh in Rendered Studio
GPU_18 - 15.10 fps - Nurbs in Rendered Studio
GPU_19 - 31.00 fps - Block Illustration
GPU_20 - 38.30 fps - 2D single
GPU_21 - 7.70 fps - 2D massive (20x)
CPU scores: 15743
CPU_01 - 9.36 sec - Booleans and Contours
CPU_02 - 1.69 sec - Twist and Taper (UDT)
CPU_03 - 4.21 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_05 - 0.05 sec - Join Render Mesh
CPU_06 - 11.02 sec - Reduce Mesh
CPU_07 - 1.46 sec - Calculating Technical display
CPU_08 - 3.94 sec - Making Silhouettes
MSI
MS-7A20
NVIDIA GeForce GTX 1080 - 4095.0 MB
DriverVersion: 22.21.13.8205
Intel® Core™ i7-6850K CPU @ 3.60GHz
NumberOfCores: 6 NumberOfLogicalProcessors: 12
MaxClockSpeed: 3.6 GHz
TotalPhysicalMemory: 32.0 GB
Microsoft Windows 10 Pro
  • None - 64-bit
Rhino 5 sr 14 64 bit
@Holo, in the test above, it’s reporting 4GB of RAM on the GTX 1080. That’s an 8GB card. Is only 4GB available to Rhino?
No. Rhino doesn’t control access to VRAM, it only reports what it finds - and occasionally gets the wrong information. But this is only reporting of information.
hello, i think i shold get more than this… any suggestions?
Here my weak result. (It’s a 11GB card.) I started the test under daily conditions - some other program are open in the back ground. I observed that the GPU power wasn’t use during the test. I’m curious for Rhino 6.
Holomark 2 v2,2,03
Total Score: 22121
Total Runtime: 172.05 sec
GPU scores: 11410
GPU_01 - 58.30 fps - Cube 4 tests
GPU_02 - 29.20 fps - UDT Shape
GPU_03 - 60.60 fps - Wireframe
GPU_04 - 37.50 fps - Shaded
GPU_05 - 27.60 fps - Rendered
GPU_06 - 26.80 fps - Block Rendered
GPU_07 - 16 units Nurbs @ 5 fps in Wireframe
GPU_08 - 8 units Nurbs @ 5 fps in Shaded
GPU_09 - 21 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 59.20 fps - RenderMesh Render
GPU_11 - 59.20 fps - RenderMesh RenderSpeed
GPU_12 - 58.80 fps - JoinedMesh Render
GPU_13 - 58.80 fps - JoinedMesh RenderSpeed
GPU_14 - 4 units mesh @ 15 fps in Shaded
GPU_15 - 5 units mesh @ 15 fps in Render
GPU_16 - 28 units mesh @ 15 fps in RenderSpeed
GPU_17 - 60.60 fps - mesh in Rendered Studio
GPU_18 - 8.80 fps - Nurbs in Rendered Studio
GPU_19 - 19.40 fps - Block Illustration
GPU_20 - 46.50 fps - 2D single
GPU_21 - 5.80 fps - 2D massive (20x)
CPU scores: 10711
CPU_01 - 10.93 sec - Booleans and Contours
CPU_02 - 2.05 sec - Twist and Taper (UDT)
CPU_03 - 4.78 sec - Meshing Mini
CPU_05 - 0.06 sec - Join Render Mesh
CPU_06 - 21.13 sec - Reduce Mesh
CPU_07 - 4.07 sec - Calculating Technical display
CPU_08 - 3.63 sec - Making Silhouettes
ASUSTeK COMPUTER INC.
Z9PE-D8 WS
NVIDIA GeForce GTX 1080 Ti - 4095.0 MB
DriverVersion: 23.21.13.8813
Intel® Xeon® CPU E5-2687W 0 @ 3.10GHz
NumberOfCores: 8 NumberOfLogicalProcessors: 16
MaxClockSpeed: 3.1 GHz
TotalPhysicalMemory: 56.0 GB
Microsoft Windows 7 Professional
  • Service Pack 1 - 64-Bit
Are you running vray by any chance? -kill the plugin during load.
How can I kill a plugin during load?
I disbaled it and started Rhino without Vray, but the results are not so different.
Thank you,
Micha
Since you have multiple cards you’ll have to make sure the card you want to benchmark is driving the primary display.
Right, the 1080 is the one for the monitor. Maybe the Dual Xeon cause the bad result.
All your top scores are close to 60 fps so it seems you have monitor syncronisation turned on. Maybe vertical syncronisation is on in your settings.
Hi Holo, I don’t understand - should I go to the Nvidia options and switch off monitor synchronization and vertical synchronization. Most I miss a better result for the GPU4 Shaded test.
I needed more cuda speed and memory so i plugged in a new Gtx-1060 6gb.
disabled vray and made a difference in the benchmark.
from 21711 to 33114.
Holomark 2 v2,2,03
Total Score: 33114
Total Runtime: 318.97 sec
GPU scores: 25530
GPU_01 - 519.50 fps - Cube 4 tests
GPU_02 - 19.20 fps - UDT Shape
GPU_03 - 33.30 fps - Wireframe
GPU_04 - 22.60 fps - Shaded
GPU_05 - 16.10 fps - Rendered
GPU_06 - 15.80 fps - Block Rendered
GPU_07 - 7 units Nurbs @ 5 fps in Wireframe
GPU_08 - 5 units Nurbs @ 5 fps in Shaded
GPU_09 - 15 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 55.20 fps - RenderMesh Render
GPU_11 - 238.10 fps - RenderMesh RenderSpeed
GPU_12 - 76.90 fps - JoinedMesh Render
GPU_13 - 333.30 fps - JoinedMesh RenderSpeed
GPU_14 - 3 units mesh @ 15 fps in Shaded
GPU_15 - 4 units mesh @ 15 fps in Render
GPU_16 - 416 units mesh @ 15 fps in RenderSpeed
GPU_17 - 51.50 fps - mesh in Rendered Studio
GPU_18 - 5.30 fps - Nurbs in Rendered Studio
GPU_19 - 13.40 fps - Block Illustration
GPU_20 - 32.20 fps - 2D single
GPU_21 - 4.60 fps - 2D massive (20x)
CPU scores: 7584
CPU_01 - 20.78 sec - Booleans and Contours
CPU_02 - 3.20 sec - Twist and Taper (UDT)
CPU_03 - 9.20 sec - Meshing Mini
CPU_04 - 0.06 sec - Extract Render Mesh
CPU_05 - 0.13 sec - Join Render Mesh
CPU_06 - 22.52 sec - Reduce Mesh
CPU_07 - 2.83 sec - Calculating Technical display
CPU_08 - 7.20 sec - Making Silhouettes
OEM
OEM
NVIDIA GeForce GTX 1060 6GB - 4095.0 MB
Intel® Core™2 Quad CPU @ 2.40GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 4
MaxClockSpeed: 2.45 GHz
TotalPhysicalMemory: 8.0 GB
  • None - 64-bit
Rhino 5 sr 13 64 bit
Great result, weak details? :wink:
Some counts like “Cube 4 tests” are impressive high, but other one like daily needed shaded mode are not so good. Strange mix.
which version of v-ray are you talking about?
because i am testing right now and vray 3.4 does not seem to be involved in the slowdown issue.
but there are many other plug ins that slow down rhino … ( t-spliines and vsr for sure)
It is both strange and not since his cpu is a core2quad with 2.4 GHz, probably an old Q6600 so that is limiting the shaded mode as it is highly cpu dependent.
Now on the other hand if you compare the cpu scores like “reduce mesh” to newer systems then you’ll see how little they have improved over a cpu from 2008 :expressionless:
And calculating technical display is actually 2x faster than the dual xeon shown above… go figure.
I would turn off those settings in the nvidia options and try holomark again, yes. I don’t know how it will affect scores that allready are below 60 hz (fps) though.
Right, that makes sense, and I see that your reduce mesh and calculate techincal display is slower than similar systems too. A complete shot in the dark can be to upgrade your BIOS as your motherboard can have a hard time with triple gpus and dual cpus at the same time.
BTW: Have you tweaked other nvidia settings too? Like 32xCSAA overrides etc? Those can be hard on systems too.
Can you boffins see any improvements to be made? I would really appreciate positive comment…
Piet de Necker
Holomark 2 v2,2,03
Total Score: 59818
Total Runtime: 147.4 sec
GPU scores: 38350
GPU_01 - 1379.30 fps - Cube 4 tests
GPU_02 - 69.40 fps - UDT Shape
GPU_03 - 125.00 fps - Wireframe
GPU_04 - 78.70 fps - Shaded
GPU_05 - 48.50 fps - Rendered
GPU_06 - 42.90 fps - Block Rendered
GPU_07 - 28 units Nurbs @ 5 fps in Wireframe
GPU_08 - 17 units Nurbs @ 5 fps in Shaded
GPU_09 - 61 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 169.50 fps - RenderMesh Render
GPU_11 - 158.70 fps - RenderMesh RenderSpeed
GPU_12 - 188.70 fps - JoinedMesh Render
GPU_13 - 125.00 fps - JoinedMesh RenderSpeed
GPU_14 - 6 units mesh @ 15 fps in Shaded
GPU_16 - 17 units mesh @ 15 fps in RenderSpeed
GPU_17 - 128.20 fps - mesh in Rendered Studio
GPU_18 - 17.80 fps - Nurbs in Rendered Studio
GPU_19 - 39.10 fps - Block Illustration
GPU_20 - 125.00 fps - 2D single
GPU_21 - 13.40 fps - 2D massive (20x)
CPU scores: 21468
CPU_01 - 6.54 sec - Booleans and Contours
CPU_02 - 0.83 sec - Twist and Taper (UDT)
CPU_03 - 3.66 sec - Meshing Mini
CPU_04 - 0.02 sec - Extract Render Mesh
CPU_05 - 0.04 sec - Join Render Mesh
CPU_06 - 8.80 sec - Reduce Mesh
CPU_07 - 1.10 sec - Calculating Technical display
CPU_08 - 2.30 sec - Making Silhouettes
System manufacturer
System Product Name
Intel® Core™ i9-7900X CPU @ 3.30GHz
NumberOfCores: 10 NumberOfLogicalProcessors: 20
MaxClockSpeed: 3.3 GHz
Microsoft Windows 8.1 Pro
  • None - 64-bit
Holomark 2 v2,2,03
Total Score: 59818
Holomark 2 v2,2,03
Total Score: 45977
Total Runtime: 147.13 sec
GPU scores: 28640
GPU_01 - 952.40 fps - Cube 4 tests
GPU_02 - 41.70 fps - UDT Shape
GPU_03 - 95.20 fps - Wireframe
GPU_05 - 41.00 fps - Rendered
GPU_06 - 39.70 fps - Block Rendered
GPU_07 - 21 units Nurbs @ 5 fps in Wireframe
GPU_08 - 13 units Nurbs @ 5 fps in Shaded
GPU_09 - 40 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 129.90 fps - RenderMesh Render
GPU_11 - 151.50 fps - RenderMesh RenderSpeed
GPU_12 - 178.60 fps - JoinedMesh Render
GPU_13 - 144.90 fps - JoinedMesh RenderSpeed
GPU_15 - 9 units mesh @ 15 fps in Render
GPU_16 - 19 units mesh @ 15 fps in RenderSpeed
GPU_17 - 120.50 fps - mesh in Rendered Studio
GPU_18 - 13.70 fps - Nurbs in Rendered Studio
GPU_19 - 29.90 fps - Block Illustration
GPU_20 - 49.00 fps - 2D single
GPU_21 - 8.30 fps - 2D massive (20x)
CPU scores: 17337
CPU_01 - 8.82 sec - Booleans and Contours
CPU_02 - 1.43 sec - Twist and Taper (UDT)
CPU_03 - 3.68 sec - Meshing Mini
CPU_04 - 0.04 sec - Extract Render Mesh
CPU_06 - 10.21 sec - Reduce Mesh
CPU_07 - 1.60 sec - Calculating Technical display
CPU_08 - 3.02 sec - Making Silhouettes
System manufacturer
System Product Name
NVIDIA GeForce GTX 1070 - 4095.0 MB
Intel® Core™ i7-6700 CPU @ 3.40GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 8
MaxClockSpeed: 3.4 GHz
Microsoft Windows 10 Home
  • None - 64-bit
Holomark 2 v2,2,03
Total Score: 74148
Total Runtime: 283.48 sec
GPU scores: 54640
GPU_01 - 1600.00 fps - Cube 4 tests
GPU_02 - 60.20 fps - UDT Shape
GPU_03 - 119.00 fps - Wireframe
GPU_04 - 78.10 fps - Shaded
GPU_05 - 52.10 fps - Rendered
GPU_06 - 50.30 fps - Block Rendered
GPU_07 - 25 units Nurbs @ 5 fps in Wireframe
GPU_09 - 54 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 181.80 fps - RenderMesh Render
GPU_11 - 333.30 fps - RenderMesh RenderSpeed
GPU_12 - 294.10 fps - JoinedMesh Render
GPU_13 - 322.60 fps - JoinedMesh RenderSpeed
GPU_14 - 10 units mesh @ 15 fps in Shaded
GPU_15 - 11 units mesh @ 15 fps in Render
GPU_16 - 519 units mesh @ 15 fps in RenderSpeed
GPU_17 - 151.50 fps - mesh in Rendered Studio
GPU_18 - 17.60 fps - Nurbs in Rendered Studio
GPU_19 - 38.30 fps - Block Illustration
GPU_20 - 113.60 fps - 2D single
GPU_21 - 11.90 fps - 2D massive (20x)
CPU scores: 19508
CPU_01 - 7.20 sec - Booleans and Contours
CPU_02 - 1.09 sec - Twist and Taper (UDT)
CPU_03 - 3.16 sec - Meshing Mini
CPU_06 - 10.22 sec - Reduce Mesh
CPU_08 - 2.44 sec - Making Silhouettes
MSI
MS-7977
DriverVersion: 24.21.13.9731
Intel® Core™ i7-6700K CPU @ 4.00GHz
MaxClockSpeed: 4.01 GHz
TotalPhysicalMemory: 16.0 GB
  • None - 64-bitowy
Needed to disable Flamingo and T-Splines plugins and set AA in GF driver to break 50k points.
Cheers, Łukasz
Here’s some love from AMD.
Ryzen 7 2700 + 5700XT
Holomark 2 v2,2,03
Total Score: 60694
Total Runtime: 319.01 sec
GPU scores: 47470
GPU_01 - 689.70 fps - Cube 4 tests
GPU_02 - 40.70 fps - UDT Shape
GPU_03 - 58.80 fps - Wireframe
GPU_04 - 42.40 fps - Shaded
GPU_05 - 31.80 fps - Rendered
GPU_06 - 30.60 fps - Block Rendered
GPU_07 - 13 units Nurbs @ 5 fps in Wireframe
GPU_08 - 9 units Nurbs @ 5 fps in Shaded
GPU_09 - 38 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 120.50 fps - RenderMesh Render
GPU_11 - 357.10 fps - RenderMesh RenderSpeed
GPU_13 - 909.10 fps - JoinedMesh RenderSpeed
GPU_14 - 14 units mesh @ 15 fps in Shaded
GPU_15 - 8 units mesh @ 15 fps in Render
GPU_16 - 724 units mesh @ 15 fps in RenderSpeed
GPU_17 - 84.00 fps - mesh in Rendered Studio
GPU_18 - 10.80 fps - Nurbs in Rendered Studio
GPU_19 - 27.20 fps - Block Illustration
GPU_20 - 55.90 fps - 2D single
GPU_21 - 8.10 fps - 2D massive (20x)
CPU scores: 13224
CPU_01 - 10.01 sec - Booleans and Contours
CPU_02 - 1.79 sec - Twist and Taper (UDT)
CPU_03 - 5.28 sec - Meshing Mini
CPU_05 - 0.03 sec - Join Render Mesh
CPU_06 - 13.06 sec - Reduce Mesh
CPU_07 - 3.87 sec - Calculating Technical display
CPU_08 - 3.75 sec - Making Silhouettes
Gigabyte Technology Co., Ltd.
X470 AORUS GAMING 7 WIFI
AMD Radeon RX 5700 XT - 4095.0 MB
DriverVersion: 26.20.13031.10003
AMD Ryzen 7 2700 Eight-Core Processor
MaxClockSpeed: 4.0 GHz
  • None - 64-bit
Rhino 5 sr 14 32 bit
