Holomark 2 Released!
I suggest that anyone having posted their results here would post also the text version so its easy to “harvest” the text results for analysis, like I did in the other thread (“Holomark 2 scores searchable text results”).
Data + regex for data extraction included in that thread, here only a small screenshot of part of the latest results (Edit: Extraction R15 16):
So, if you already posted your results as an image, please post also your results in text format! (here or even better, in the other thread)
Attention: Also try not to change anything in the text produced by Holomark because then it gets difficult to find matches with Regex (regex isn’t as smart as program code in considering alternative scenarios).
// Rolf
Long story short:
1st: NO AA
2nd: 2x AA
3rd: 4x AA
4th: 8x AA
I just built myself a new pc. way back when this thread first started I posted my score of my old computer. my score was always 28-30k. here is my new one. check out gpu test#16. that is a crazy # of units lol
Jeez… that would have taken a hell of a long time… Holomark2’s lack of futureproofing is showing… must be an immature programmer that made it! :smiley:
Haha, cant wait a new benchmark for rhino 6. You could make it better and sell it. I will buy it for sure!
Surface Book w/ Performance base.
with a 4K external monitor (while laptop display used as second monitor):
using it standalone (no second monitor):
Macbook pro 2015 15" running Windows 10 in bootcamp with GeForce 750m.
4XAA on battery:
No AA on battery:
Cabled power, max power settings, no AA:
And finally Cabled power, max power settings, 4xAA:
So it seems this older nVidia card doesn’t benefit on the GPU_16 RenderSpeed test from turning off AA.
Finally got my overclocks dialed in.
Cpu @ 4.6
Gpu @ 2075
NICE! Core speed for the win!
very nice, this may very well be the highest score ever posted here!
@thompsonburry
do you know why it says “GTX 1080 - 4095.0 MB” although the card hat 8GB?
is rhino only able to make use of 4GB vram max?
I actually didn’t notice the 4095.0 MB. Seems strange. The user a few posts above mine jimc also has a GTX 1080 reading 4095.0 MB, is this the case with the larger quadros as well?
Yeah, this is something I have to revisit for the next Holomark. It just pulls the data from Windows, so why it shows up as 4095 (And not 8192 or at least 4096) is currently not something I know.
here my system with an RX460:
but because I want to be able to utilize cycles in the wip, I just swapped it against a GTX1060-6GB (Zotac AMP):
Lenovo Yoga 900 running Windows 10 with 4K external monitor and 4XAA. Laptop display driver is set at 3840 x 2160 but Rhino 5 sets display resolution to 1536 x 864 which seems conservative. Are others seeing this much downgrade with a 4K display? Rhino 6 WIP uses the full screen resolution which is one of its new features.
Seems like my CPU score is quite low, especially (UDT) score. Any reason what’s causing it?
Please help! Thanks in advance.
MSI Z170 | i7 6700k | 32 Gb ram | Connected to two 1440p monitors | 4xAA
Holomark 2 v2,2,03
Total Score: 26557
Total Runtime: 150.8 sec
GPU scores: 18260
GPU_01 - 384.60 fps - Cube 4 tests
GPU_02 - 55.20 fps - UDT Shape
GPU_03 - 91.70 fps - Wireframe
GPU_04 - 64.50 fps - Shaded
GPU_05 - 43.90 fps - Rendered
GPU_06 - 42.70 fps - Block Rendered
GPU_07 - 21 units Nurbs @ 5 fps in Wireframe
GPU_08 - 12 units Nurbs @ 5 fps in Shaded
GPU_09 - 13 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 125.00 fps - RenderMesh Render
GPU_11 - 81.30 fps - RenderMesh RenderSpeed
GPU_12 - 158.70 fps - JoinedMesh Render
GPU_13 - 65.40 fps - JoinedMesh RenderSpeed
GPU_14 - 3 units mesh @ 15 fps in Shaded
GPU_15 - 9 units mesh @ 15 fps in Render
GPU_16 - 4 units mesh @ 15 fps in RenderSpeed
GPU_17 - 105.30 fps - mesh in Rendered Studio
GPU_18 - 14.50 fps - Nurbs in Rendered Studio
GPU_19 - 31.30 fps - Block Illustration
GPU_20 - 61.30 fps - 2D single
GPU_21 - 9.40 fps - 2D massive (20x)
CPU scores: 8297
CPU_01 - 7.94 sec - Booleans and Contours
CPU_02 - 32.14 sec - Twist and Taper (UDT)
CPU_03 - 3.16 sec - Meshing Mini
CPU_04 - 0.12 sec - Extract Render Mesh
CPU_05 - 0.04 sec - Join Render Mesh
CPU_06 - 11.08 sec - Reduce Mesh
CPU_07 - 1.60 sec - Calculating Technical display
CPU_08 - 4.18 sec - Making Silhouettes
MSI
MS-7971
NVIDIA GeForce GTX 780 Ti - 3072.0 MB
DriverVersion: 21.21.13.7866
Intel® Core™ i7-6700K CPU @ 4.00GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 8
MaxClockSpeed: 4.01 GHz
TotalPhysicalMemory: 30.0 GB
Microsoft Windows 10 Pro
  • None - 64-bit
Rhino 5 sr 12 64 bit
Dell Precision M4700
Holomark 2 v2,2,03
Total Score: 27272
Total Runtime: 193.81 sec
GPU scores: 18110
GPU_01 - 481.90 fps - Cube 4 tests
GPU_02 - 21.70 fps - UDT Shape
GPU_03 - 54.60 fps - Wireframe
GPU_04 - 31.30 fps - Shaded
GPU_05 - 20.40 fps - Rendered
GPU_06 - 19.80 fps - Block Rendered
GPU_07 - 12 units Nurbs @ 5 fps in Wireframe
GPU_08 - 7 units Nurbs @ 5 fps in Shaded
GPU_09 - 17 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 59.20 fps - RenderMesh Render
GPU_11 - 238.10 fps - RenderMesh RenderSpeed
GPU_12 - 46.30 fps - JoinedMesh Render
GPU_13 - 303.00 fps - JoinedMesh RenderSpeed
GPU_14 - 4 units mesh @ 15 fps in Shaded
GPU_15 - 3 units mesh @ 15 fps in Render
GPU_16 - 41 units mesh @ 15 fps in RenderSpeed
GPU_17 - 21.80 fps - mesh in Rendered Studio
GPU_18 - 6.40 fps - Nurbs in Rendered Studio
GPU_19 - 15.50 fps - Block Illustration
GPU_20 - 31.40 fps - 2D single
GPU_21 - 3.90 fps - 2D massive (20x)
CPU scores: 9162
CPU_01 - 16.50 sec - Booleans and Contours
CPU_02 - 2.49 sec - Twist and Taper (UDT)
CPU_03 - 6.76 sec - Meshing Mini
CPU_04 - 0.05 sec - Extract Render Mesh
CPU_05 - 0.06 sec - Join Render Mesh
CPU_06 - 20.11 sec - Reduce Mesh
CPU_07 - 3.14 sec - Calculating Technical display
CPU_08 - 5.46 sec - Making Silhouettes
Dell Inc.
Precision M4700
NVIDIA Quadro K1000M - 2048.0 MB
DriverVersion: 21.21.13.7633
Intel® HD Graphics 4000 - 2080.0 MB
DriverVersion: 10.18.10.4358
Intel® Core™ i7-3740QM CPU @ 2.70GHz
MaxClockSpeed: 2.7 GHz
TotalPhysicalMemory: 8.0 GB
Microsoft Windows 10 Professionnel
  • None - 64 bits
HI I have the message ERROR: HM2_Wire was not propperly installed. I really want to try this. Thanks for help!
Not bad for a 14inch laptop…
Hello Holo I solve ERROR: HM2_Wire was not propperly installed. Just changing to englis my rhino… but this is my score I think its to low for my pc config. If anyone have a tip it will be great. thanks
Hi John,
I don’t know why the display modes failed to install when Rhino wasn’t english, but Holomark SHOULD check to see if Rhino is in english! Hm… what language are you using?
And unfortunately I have no idea why some Xeon’s and some new many-core-i7’s get slow GPU_01, GPU_02 and CPU_02 scores. I don’t think it affects real life modelling much, it mainly slows down running some scripts as far as I know… And I don’t think RMA knows what’s causing that either.
